D
Deleted member 89374
I've not found a reason to switch to other oils that meet (or claim to exceed) the spec e.g. Lucas and Amsoil.
You're absolutely right and spot-on, however, the life of the turbo is shortened. Also, if everyone was towing heavy loads on ILSAC 5W-30 oil with their EcoBoost powered F150s, those failures would be more prevalent....
Add the fact that the turbo bearing housing is water jacketed with a "turbo timer" and separate coolant circuit .on most cars so the lubricant heating in the unit is through shear and then impeller shaft heat transfer from the ex side turbine. Given good flow, coking should not be an issue anymore.And your evidence for this is?
The Ford GT (supercar) and a few of Ford's other performance vehicles are specified to use 5W-50 synthetic (The GT is specified to use Castrol Edge Supercar 5W-50 specifically in the owner's manual, but it meets a Ford specification). That got me thinking, so I looked up the VVT solenoids from the GT and they are common with Ford's other engines (2.3L, 3.5L, 5.0L, etc...) It seems to me that mechanically speaking, the 5W-50 synthetic would run in the majority of Ford's engine lineup. I remember Ford Australia's modular V8s (which were made in the US) being specified to use a 5W-50 synthetic while the same engines in the US were spec'd to use 5W-20.
The reason for me asking is that it looks like the internal water pump on the Duratec V6s (3.5/3.7) have a non-sealed bearing that relies on engine oil to lubricate the needle/ball bearings. Someone used a water jet to cut apart the failed water pumps and saw flat spots on these bearings. I'm thinking the bearings probably failed due to a lube issue, causing the shaft to overheat and destroy the shaft seal, causing the coolant to flow into the engine oil. Since the majority of these engines are running 5W-20 or 5W-30 as well as in police fleets with 50k water pump changes, maybe those oils aren't providing enough protection? There are lots of reports of timing chain "stretch" (basically wear) on these engines as well. I have a friend whose Explorer Sport (3.5L EcoBoost) with under 50k miles had to have the timing chains replaced due to "stretch".
Could very well be!Some of the timing chain wear may be attributed to soot accumulation from the DI combustion process in these engines. Thicker oil may provide a wider mechanical separation of metal links in the chain, keeping the soot particles from wearing the metal. shorter OCIs may reduce the amount of these abrasive particles as well.
This is correct. Its dependent on the size of the compressor exducer usually, they dont want to exceed 540 m/s tip speed. Since a larger compressor reachs this tip speed at a lower rpm, they will have lower speed limits.Doesn't it actually depend on the size of the turbo and how it's set up? For example, a turbocharger on a big truck diesel engine doesn't need to spin as much as on a gasoline engine to create 25 PSI of boost. I've been reading different things over the years as far as turbocharged gasoline engines are concerned, so I assumed a worst-case scenario. If you do a quick Google search you will find various results from various sources that say different things.
So is 5W-30...Add the fact that the turbo bearing housing is water jacketed with a "turbo timer" and separate coolant circuit .on most cars so the lubricant heating in the unit is through shear and then impeller shaft heat transfer from the ex side turbine. Given good flow, coking should not be an issue anym
In the two F150s I owned with the 5.0, I ran 5w-30 and 0w-40. Both without issue and neither had noticeable power or mpg difference from the 5w-20. Very smooth on the -40.
I'd say bumping up the viscosity is a good idea since the 20 grade is for CAFE.
(Nice resurrection snagglefoot)![]()
As soon as FoMoCo provides me with their turbocharger failure starts, I will be sure to pass them on to you. In the meantime, common sense will have to suffice, as turbochargers need good oil. The quality of oil that we put in our vehicles is one of the few things we as owners control. The bearing quality in turbochargers might vary from manufacturer to manufacturer. That's why some turbos can last longer than others, even on crappy motor oil. I've seen this plenty of times in turbodiesel engines.And your evidence for this is?
So is 5W-30...
Everyone has the freedom to run whatever oil they want in their motor, whether it's for added protection or just for "warm and fuzzies".![]()
Yup, so the move by many on here to a 40 is a good one.So is 5W-30...
Yup, so the move by many on here to a 40 is a good one.![]()
You think car manufacturers even get any CAFE credits for xW-30 or higher? Did they ever?So is 5W-30...
Em, pretty clearly they did in the 1990's...You think car manufacturers even get any CAFE credits for xW-30 or higher? Did they ever?
Doesn't mean they still get CAFE credits for xW-30 today ... and hence the drive to xW-20.Em, pretty clearly they did in the 1990's...
Did you think that 5W-20 suddenly came out of a vacuum in 1998-99'?
Yes, I know ... using the term "credits" meaning using whatever means are used to achieve the monetary "pay-off" so to speak of meeting the fuel economy goals. There are lots of ways to do it, but seems oil viscosity is an easy way to do it ... easier than many other things.And whatever one thinks of "CAFE", do they really give the so-called "credits" on a weight of oil or the overall fleet fuel economy average?
