A UOA after a couple of dyno pulls on an engine that was designed 70 years ago doesn’t quite do it for me.
My son bought a 2012 F350 a month ago with 227,000 kms on it for $9,500 Canadian.
He drove it from Terrace, BC to Kamloops, 1,200 kms and it used 1.5L of 5w20. We topped it up before he drove to Vancouver and back and it was down another litre in 1,200 kms.
I drained the 5w20 and ran some SAE 40 in it for 100 kms, drained it and put in the Delo with a new filter.
The truck made it back to Terrace with a two hour stop over in Prince George to change the alternator on the side of the road, without using any oil. So far so good.
This is the first Ford truck in the family after decades of GMs, and there’s a learning curve.
The ignition system is a “wasted spark” with four coils on top of each valve cover that fires two spark plugs per cylinder. One on the compression stroke and the wasted one on the exhaust stroke.
The coils were arcing to the engine causing a misfire. The previous owner had replaced the top row with platinum spark plugs that had three times the gap from new, and the bottom row that are hard to change were the originals.
