I'm wondering if anyone's tried this with success. I can get this oil really cheap, so I wonder if it's ok for year round use and 4k or so oil changes?
So Gary, do you think the 40w-70 I used to run in my Jeep 258/4.2 litre was a tad on the thick side.quote:
but it is a tad heavy if you're a short trip type. It may cost you a bit more in fuel
If you've got exceptionally high Fe ..I would say that you're not in a short trip environment service-wise. M1 tends to give higher Fe readings ..or so many suggest. Mine went from the high 70's for 10k on M1 Xw-30 to under 30 for 10k on Delvac 1 5w-40. Most, but surely not all, who have reduced Fe readings with dino 30 weights, tend to not be highway commuters of any substantial merit - YMMV.quote:
I've been running my TJ (which is now knocking on the door of 40k) on a steady diet of M1 10w-30 since 500 miles but I've now had two oil analysis done by blackstone and my iron is high, way high and I'm looking at other alternatives. Last analysis at 3500 miles on the oil showed 49 ppm iron, which scares me.
Why so light? I'm sure that you can do better than that.quote:
So Gary, do you think the 40w-70 I used to run in my Jeep 258/4.2 litre was a tad on the thick side.![]()
oooh, a challenge !quote:
Ouch. Your son's starter, oil pump drive shaft and oil pump are probably not happy on those cold morning starts. I'd be careful.quote:
Originally posted by Gary Allan:
..but 15w-40's worked well in my son's 4.0 into the single digits last winter.
