Yup. 4.0L4 cyl? Every 4.0 online 6 even back to the 258 days holds 6.
The 2.5 four cyl holds 4
You had the wrong dipstick, wrong tube or a smashed oil pan. Every 4.0 holds 6 regardless of year or what it's inYup. 4.0L
No you got me thinking of blending some of my 15w40 with some 0w20 and 0w30I have seen 4.0 Jeeps with over 1/2 million miles on them on synthetic 5w30. Why in the world would anyone deviate from that? It is, after all, the manufacturers recommendation. I´m sure the manual probably said 10w30 was ok in warmer climates, too.
Nobody EVER ran a 4.0 at the track, so I´m not sure why some folks think a 40 weight would be good for that engine.
OP, if it were mine, I´d just swap it right out for some Mobil 1 5w30 and rest easy as the miles roll by.
10w30 is the factory recommend weight for any temp above 0 deg F (that's from my 01' WJ owners manual). All this is overthinking on these. They aren't picky. If there is a consideration to oil it should be for oil pressure and what weight works best in that regard as they are somewhat known poor oil pressure over time. My 30k mile 4.0L has seen 3 oils: Quaker State full synthetic 10w30 for the first 600 miles, followed by Rotella T6 10w30 for a good 20k miles and I finally settled on Castrol Euro 5w30 mainly for the A3/B4 HTHS 3.5 minimum because it's suitable for ALL our vehicles (a VW 2.5L Jetta, the Jeep and a 1rst gen Nissan Titan 5.6L with 215k miles).It is, after all, the manufacturers recommendation. I´m sure the manual probably said 10w30 was ok in warmer climates, too.
Doesn't this completely depend on what "cold" is defined as? I agree with you if we're talking -10 degrees F cold start, but for summertime "cold" starts in most places, wouldn't this be totally fine? Tons of diesel engines are running 15W oils every day of the year in all areas of the country just fine.I would avoid 15w40 like the plague. 15w40 is unhealthy at startup, especially on a cold morning.
Not that I noticedIs it also sluggish when the 10w30 is cold?
My owners manual says 10w30 down to 0F and not to use 5w30 over 32f.I have seen 4.0 Jeeps with over 1/2 million miles on them on synthetic 5w30. Why in the world would anyone deviate from that? It is, after all, the manufacturers recommendation. I´m sure the manual probably said 10w30 was ok in warmer climates, too.
A Jeep 4L isn't a diesel engine. If you want a thicker oil for it then use a thick per grade 5w30 syn or a 5w40 syn. I belonged to a Jeep club. We did offroading. 5w40 syn and thick for the grade 5w30 syn were commonly used in Jeep 4L and 4.6L strokers with good success in a wide variety of climates on & off road.Doesn't this completely depend on what "cold" is defined as? I agree with you if we're talking -10 degrees F cold start, but for summertime "cold" starts in most places, wouldn't this be totally fine? Tons of diesel engines are running 15W oils every day of the year in all areas of the country just fine.
I think you're reading or interpreting it wrong. In any case, your owners manual oil recommendations are decades obsolete. 5w30 oils have gotten much better. You could run a modern 5w30 syn year round just fine, especially if it's a 5w30 that is on the thick end of 30 grade.My owners manual says 10w30 down to 0F and not to use 5w30 over 32F.
