Like my Subaru Crosstrek. **** thing idles high for a full minute before it comes down. Ain’t nobody got time for that.High idle sometimes stays on for a while.
I think this is an important distinction that should be made with this conversation. I don’t believe anybody is suggesting that people should drive around with ice/snow all over the windshield. Idling to get the vehicle thawed for safety reasons makes perfect sense. So does warming up the vehicle for personal comfort when it’s extremely cold. Both of these are logical and sound.I have to idle for at least 5 minutes to get the ice frozen off all the glass
That is why, if car parked outside, always front toward the house, as close as possible. Windshield ice collection is dramatically lower.I think this is an important distinction that should be made with this conversation. I don’t believe anybody is suggesting that people should drive around with ice/snow all over the windshield. Idling to get the vehicle thawed for safety reasons makes perfect sense. So does warming up the vehicle for personal comfort when it’s extremely cold. Both of these are logical and sound.
What people are attending to, hopefully, is the OP suggesting that it is harmful to the ICE to not idle more which is something altogether different.
Shake My Head
Thanks. That makes sense and why it warms up so quickly.EA888 has exhaust manifold integrated into cylinder head. Coolant passages go around exhaust runners. It warms up much faster, has better thermal regulation and mpg is better.
Out Tiguan needs a minute to start heat in subzero conditions.
Agree. Certainly do not think anything is wrong with gentle idle to warm up engines. Often wonder if setting the heater high at first will help speed engine warm up?No doubt that getting cabinet heat is a priority. Still advocate some idle time. But definitely turn on seat heater and steering wheel heaters if you have them. In most cases, you will have minimal heat until the engine and coolant heat up.
That has the exact opposite effect since it draws heat from the cooling system. If you are warming up the engine while idling it’s going to warm up faster with the cabin air temperature set as cold as possibleAgree. Certainly do not think anything is wrong with gentle idle to warm up engines. Often wonder if setting the heater high at first will help speed engine warm up?
The opposite. On an old Sentra we had, having the heater on full blast was enough to keep the radiator ice cold after driving a hundred miles in 20f temps. Leaving the heater off in cold weather meant the temp gauge came up to operating level in half the time.Agree. Certainly do not think anything is wrong with gentle idle to warm up engines. Often wonder if setting the heater high at first will help speed engine warm up?
Recently, I discovered that (or a similar) feature in a Lexus. I imagine that there are some variations in how the heat is produced. However, it should be noted that not all cars have that feature.You will find an electrical heater grid in the HVAC system that gets the heat going way before the engine can make heat.
I give it enough time to put my seatbelt on.
Ha, we don’t wear coats here in Phoenix, just either a light zip up jacket or a hoodie.Do you put on a coat when it drops below 100° F?
The coolant valves and pump setup is brilliant and they pump coolant through the turbo which heats it that much faster. My GTI was pretty quick to get heat too.Volkswagens (water cooled) have always had excellent heating performance.
