I have just done a Pump Rub and Rear Main Bearing upgrade on my NVG246 Autotrac transfer case(4 Buttons, Auto4WD,2Hi,4Hi&4Lo)in my 2002 2500 Suburban. The General's Owners manual for this Truck says that I must use Autotrac II fluid because there are additives(friction modifiers)in the fluid that lubricate the clutches and prevent chatter. I have been looking for an alternative full synthetic fluid to use in place of the Autotrac II fluid which is basically just FM modified Dex III that is blue in color. I have read and spoke with RP and was told that their Synchromax would be a good substitute for the Autotrac fluid. They claim it's spec'ed much better as well and will work fine with the clutches in the TC. Has anyone, or does anyone know of anybody that has used Synchromax in place of the Autotrac II fluid. Even if you haven't done this I would like opinions on whether I should do the switch or stick with the Autotrac II fluid. Also, if anyone knows of any other company that makes a synthetic substitute, I'm listening.
