MAKE UP FLUID MAKE UP FLUID UNITS
0.0
METER ON FLUID FLUID CHANGED
3/31/11 NO PROBLEMS PRESENTLY ASSOCIATED WITH THIS SAMPLE. CONTINUE SAMPLING AT THE NORMAL INTERVAL.
FILTER CHANGED
Yes
No Action Required
4/4/11 5700 MI
110 MI Yes
Wear Metals (ppm)
Cu Fe Cr Al Pb Sn Si Na K B Mo Ca Mg Zn P
E140-41094-0408 0 8 0 1 1 0 4 1 0 133 6 3353 386 1848 1334
Oil Condition / Particle Count (ct/ml)
ST OXI NIT SUL W A F V100 TBN
E140-41094-0408 3 13 6 18 N N N 11.3 6.5
Ag = Silver, Al = Aluminum, B = Boron, Ca = Calcium, Cr = Chromium, Cu = Copper, Fe = Iron, P = Phosphorus, K = Potassium, Mg = Magnesium, Mo = Molybdenum, Na = Sodium, Ni = Nickel, Pb = Lead, Si = Silicon, Sn = Tin, V = Vanadium, Zn = Zinc, A = Antifreeze, F = Fuel, W = Water, P = Positive, N = Negative, T = Trace, E = Excessive, NIT = Nitration, OXI = Oxidation, ST = Soot, SUL = Sulfation, ISO = ISO Rating, PFC = Percent Fuel Content, PQI = Particle Quantifying index , NaW = Salt Water, FL Pt = Flash Point, TAN = Total Acid Number, TBN = Total Base Number, H2O = Karl Fisher result, V100 = Viscosity@100C, V40 = Viscosity@40C
Notice: This analysis is intended as an aid in predicting mechanical wear. No guarantee, expressed or implied, is made against failure of this piece of equipment or a component thereof.
PS How do I post pictures here?
Dusty
0.0
FILTER CHANGED
Yes
No Action Required
4/4/11 5700 MI
110 MI Yes
Wear Metals (ppm)
Dusty
