Royal Purple oil filter application chart
Originally Posted By: kosstick
1. Will the 10-2867 work on my Infiniti G37? The RP site recommend the 10-2876, but a few people on the the370z.com forums used the Nissan GTR filter recommendations because it is taller and for RP the filter for the GTR would be 10-2867.
If the engines are basically the same and filter mounts the same and you have the room for a taller filter, then it should work fine.
Any idea on my 2nd question. Appreciate the feedback!
2. Do some filters work better with different types of oil? For instance I am going to start using Motul 300v power 5w-30 (ester oil).
I doubt the filtering performance of a filter is dependent on the oil used. I've never seen any data or talk associating the oil type with filter performance.
Do keep in mind that using a thicker oil will cause the pressure drop across the filter to increase, but if you're using 5W-30 I wouldn't worry about that being an issue.
Originally Posted By: kemo
Originally Posted By: daman
Are you sure?
looks are one thing but what about media design? dirt holding capacity?,media thickness?,flow?,efficiency/beta ratings?
do we know this stuff?
yes, "we know this stuff" same exact filter. I wouldn't have gone through the trouble to make the video to prove it.
K&N
Outside Diameter: 3.000 in. (76 mm.)
Height: 5.140 in. (131 mm.)
Thread Inside Diameter: 1
Thread Number: 16
Mobil1
Outside Diameter: 2.990 in. (76 mm.)
Inside Diameter: 3/4 in. - 16 thread
Height: 4.750 in. (121 mm.)
Thread Number: 16
