Originally Posted By: ARCOgraphite
Isn't synerlec a sulfur compound? (which is NOT in the ILSAC AOI starburst cert lubes) IIRC the performance oils show high sulfur - maybe Im incorrect .... IDK.
It's a sulfurized-ester.
Here is what RP tech support told me a while back:
The only RP SAE street oil that still contains Synerlec is the 5W-40 (part #01540, quart bottle). The update to API SN and ILSAC GF-5 required compliance with chemistry restrictions that precluded the use of Synerlec and required a reduction in anti-wear additive. We did introduce a new line of performance street oils, though. Royal Purple HPS oils are an improvement of the older street synthetic oils, all containing a generous dose of Synerlec and high levels of anti-wear additive. Unfortunately, they will likely need to be special ordered through a local Napa, O’Reilly or CarQuest, or you can get them online at Jegs.com, Lucky7Trucks.com, PacePerformance.com, and SummitRacing.com.
