I don't see how RP could be close to 80% syn if it thins out noticably in a couple thousand miles. I use their gear oil and really liked the motor oil but pulled it at 4k mi as it just felt too thin at that point. If it were cheaper I would consider using it anyways but at RPs price I would expect at least a 5k oci for their street oils. I know RP says that wear is not a problem with extended drains, but I prefer a more stable viscosity and oils that thin quickly are more likely to leave deposits in extended drains even if the wear seems OK. RP racing oils seems better but cost even more and aren't API rated. The fact that RP street oil probably isn't 80% syn doesn't bother me. If it's 80% dyno, it wouldn't stop me from using it. It's the sheer instability of the dyno in the mix that does. It costs enough for them to fix this and blow us all away.
