There is only one brand of oil that I have seen no shear in any circumstance out of all the UOAs posted here.
Originally posted by Patman:
[QB] Nobody from Royal Purple has ever answered...."
Patman,
Many months ago I emailed you privately and offered for you to call me toll free.
I'll repeat it again. I would like to help but my job duties do not allow me the time to monitor all of the web forums that RP gets discussed in.
Toll Free 888-382-6300 x202
main number 281-354-8600
Fax 281-354-7335
direct email [email protected]
Having reviewed Ed's baseline oil reference and the used oil sample, the slightly reduced viscosity (9.21 cSt @ 100 C) appears to be due to some form of contamination reducing the flashpoint by 30 degrees as accurately identified by Drstressor in several posts.quote:
Originally posted by Drstressor:
Ed -- Your post indicates 0.5% fuel and a reduced flash point.
Patman,
Fax 281-354-7335
direct email [email protected]I never recieved the email.
Why not discuss it here for all to see though? I know many people would like to know why RP thins out so easily when other 10w30 oils don't.
Where did Dave C tell me the reasoning behind it thinning out? I never received his email, and as of yet he still hasn't posted it on here either. I see no reason why he wouldn't post it here on the forum. If I phone and talk to him in person, I'm just going to repeat what he says on here anyways, as this forum has a right to know the answer.quote:
Originally posted by PRRPILL:
Patman,
You are amazing. DAVEC tells you the reason the oil has a lower vis, and all you can do is make it sound like he wants keep it under covers. He is trying to rsolve an issue for you, without getting all the usual brand loyalty BS from others. If you would listen, maybe you would have your answer. How many of the other oil companies have answered you, and how many want to do it on this forum?
I did read it, but that only explains why Royal Purple sheared IN THIS CASE but it does not explain why it shears back in other cases when there is no contamination, such as my wife's sample where it went from 11.4 down to 8.8cst, but with no fuel whatsoever in the oil (sample came back with 0.0% fuel in it)quote:
Patman,
Read the posts 4-5 above........
