tmorris1Higher freqs do not penetrate better than lower freqs. See how many walls can be between your 5GHz signal versus the 2.4GHz. [/quote said:
I stated that poorly, I dont mean to penetrate a dense substance, I mean to 'enter and reflect in' a partially enclosed space. your office at work is a good example, unless near a window where the entire AM wavelength has a direct path to your radio, you may get zero reception, but if a much smaller cell phone wave is able to get entirely inside the building and between each 'bounce point' and eventually your cell, it works.
this distinction may not be that important in say less dense wood structures, but in a dense concrete and steel building, its the world.
