Originally Posted By: johnachak
It hasn't warmed up yet? I use Full Synthetic oil in mine as it runs smoother and warms up quicker when cold (2006 3.0l Ford)
Too bad your car heats up quicker with the high friction and drag oil you put in it. Consider using an oil that heats up SLOWER. An oil would have to be horrible to make an engine heat up faster.
To the OP:
Vacuum leaks, Dirty MAF, coolant sensor, or dirty TB and idle air valve should be checked.
