Originally Posted By: Roob
My current setup includes Wagner TQ ceramic with EBC slotted rotors at all four corners and this is why I switched and my experience.
Wet weather performance and fade.
The OEM setup had a noticeable initial delay before biting in the rain and was not something I could tolerate.
This problem manifested at every initial wet weather braking event.
In dry and hot the pad performance with heavy use had a tendency to fade. All that adds up to lower brake performance and increased stopping distance. Not acceptable for me where brakes are concerned. Now YMMV but this really bothered me and I wanted better than OEM and knew it had to be possible. "One size fits all" doesn't really work for me and I'm not good at just accepting and tolerating these types of things.
So after reading, asking and trolling I saw what could be a solution to significantly reduce or eliminate the issues I was having and went for it. From my experience with these new slotted rotors and ceramic pads my braking performance over OEM has increased greatly. The initial brake bite delay in wet weather is no longer an issue and I have yet to experience any fade with continual heavy use. No auto cross here but the 401 can come pretty close in certain areas at certain times.
Overall braking performance has substantially increased. So for me it was a worthy venture, although not cheap.
As I said in the beginning, this is my experience and yours may be different. I had a specific problem and this was the solution. Slotted rotors and ceramic pads corrected an issue I was having and increased my safety.
Some things that you'd think should just belong on a racetrack can yield positive results on the road to.
Definitely a real world experience for me.
Cheers.
My mechanics told me these OE rotor on Accord are junk. A friends told me slotted rotors is rust and have high pad wear, maybe he got a bad brand.
