Originally Posted By: wsar10
Am I using it for the wrong reasons ??
Ive been around jeeps my whole life and my dad used to use Rotella in some of them cuz we had it around for bobcats and tractors.
My 4.0 has NEVER ran smoother and quieter, even the "infamous" lifter sound at startup is pretty much gone (i'm sure it will be back) I figure anything that helps my motor last longer "I'm in". from looking at tons of info on here the 4.0 is said to show very good wear numbers with HDEO.
I did not want something like 15-40 (I know guys that run it) that just seems TOO HEAVY at starup, I guess. Seems like 15 would create a "dry start" issue in the long wrong (maybe i'm wrong). I ran T5 for 2k mi and drained it as I read on here that using a deisel oil could break build up free inside my motor and there is a chance the filter would not catch it,the oil came out black as coal, the new oil seems to be maintaning it's golden color. I used to use ML and I read about formula changes and saw a comment in a VOA post on here that exclaimed "where's the good stuff" so that was it, I jumped on the "4.0 has better results with a HDEO" boat.
since my switch I've avg 1-1.5mpg increase, I was also told on here that the T5 add pak is very similar to that of a High Mileage oil, that includes "seal conditioners" and jeeps are know for oil leaks, I have none.
I'm also stuck on 4k OCI with P1 or wix filter I used to use K&N but i'm tired of paying for two letters when the P1 seems to work aswell. I know I know I have seen th science behind the facts of extended OCI's and I know I can go longer or I could save money by going with dinno, but i'm ok with it.I also wanted an oil that I could run in my lawn equipment and pretty much anything else in my garage.
I guess these are my thoughts, am I way off or ok ?
I'm far from knowing everything about oil or understanding alot of this. but thats why i'm here.
