I would NOT feel comfortable with a product such as the Mobil 1 15w-50, which is NOT marketed for bikes, does NOT have MA recommendation, and is NOT recommended for wet-clutch applications. But that does not stop others from using it, and they generally report no issues.
Just curious, WHO does not recommend Mobil 1 15W-50 for wet-clutches? Simply because its not JASO MA rated?
I've always operated under the principle, non-EC oil and I'll use it in my bike (w/ wet clutch). Never caused me any issues. I think you know it costs money ($$$) to certify oils to certain standards. Just because its not rated, doesn't mean it wouldn't pass or pass for that matter. For motor oils, motorcycles are a niche market... so there are fewer choices and generally more expensive as compared to passenger/diesel oils.
I am taking Mobil for the words at face value.
Mobil has a few products that are specifically marketed and "recommended" for service in bikes, and some of them actually mention "wet clutch" in the marketing description. (see the PDS links I put in above).
Mobil also has the 15w-50, which is NOT:
- marketed for bikes
- has no JASO-MA recommendation by Mobil
- has no "wet clutch" application recommendation by Mobil
I can find absolutely nothing in their product data or marketing info that states there is any reason to believe they want this in a wet-clutch bike.
As I said previously, that does not stop some folks from using it, and generally they report no issues. But I, for one, would prefer to use a product that is at least "recommended for use" for the application, as it gives a much better stance concerning warranty claims, should it become necessary to go that route.
If you read most any written limited warranty (including the Mobil warranty I linked), they clearly do NOT warrant any application of a product that is outside of their specific license or recommended ventures. Therefore, using 15w-50 Mobil 1 in a bike will void any warranty condition they offer.
I am not stating that non-EC oils won't work in a bike.
I'm just trying to delineate the choices for folks so they understand both the benefits and risks for each option.
The OP wanted to know about T5; it's not recommended for MA service requirements, nor is it recommended for wet-clutch applications. Same can be said about the 15w-50 Mobil 1. That does not mean they won't work, but it does mean you'll have zero coverage should something bad happen. And because both companies (Mobil and Shell) do offer products that meet the criteria (MA and wet-clutch concerns), why use a non-recommended product when they have recommended products available? To me the risk outweighs the reward; it's not worth it to exclude warranty coverage when I can easily get low-cost products that directly meet the application.
To each his own.
I was just curious if they [Mobil] specifically didn't recommend it... appears they don't, but also don't not-recommended it. Confusing, right? Which in my opinion can simply be a marketing-thing to delineate their passenger motor oils from the motorcycle ones... maybe not.
As far as warranty, the dealer would have to prove you used non-factory recommended oils... and the oil caused the issue. Worst case I can only imagine is a slipping clutch and that can be fixed either with an oil change, cleaning the plates or new plates. However that’s a whole other topic. I’m pretty sure people do a lot of things beyond what the manufacturer recommends, right or wrong…
Anyway rant-off
Call Mobil and ask them, I did. They will steer you towards the Motorcycle oils but they told me their Mobil 1 15W-50 would work fine in my Concours 14. I have 500 miles to go (for 3,000 miles) and I'll be posting a used oil analysis on the 15W-50. The oil has performed great so far
But of coarse every time I mention Mobil 1 15W-50 Larry (BLS) comes by saying my motor is wearing out cuz that oil ranks 150 something on the RAT oil protection chart....????
