Rotella T 10w-30 Diesel oil.
Michigan
Anyone see this on the shelf at Walmart? Anyone do an analysis on it?
It has all the same ratings as the 15-40, with exception to the CI-4"Plus"....
I used it in some gas cars for ARX treatments. Worked well. More 10w-30 HDEO brands should be coming to market.
Why more 10W-30? Is this just a natural byproduct of petrol-engine spec upgrades, or are manufacturers starting to push 10W-30 oils for use in the traditional fleets of diesel engines?
Ford 6.0 PSD specs 10W-30.
Also I expect to see the HD Fleet going to 30 Weights in the next couple of years as they look for MPG increases.
Gene
In my research Rotella had the highest concentrations of Zinc and Calcium vs the other HDEOs. Shell is also using mostly Group II now, so cold pumping is improved.
Gene
Gene in the 1970's most all cummins used straight 30 wt .I remember that 15w/40 was a gift for cold starting compared to the 30 wt.
10W-30 will replace 15W-40 as the "usual" diesel engine oil viscosity in the near future. Both improvements in the oil and the quest for improved fuel mileage will be responsible.
Ken
I used 10-30 Rotella for 10 years in a Mercury Villager (Quest in disguise). Finally traded it with 212,000 on the clock, still running like new, and not using any oil. IMHO, it's a fine oil.
