Roll on bedliner tips?
Seabrook, TX
My Son is currently prepping the bed of the Colorado work truck I bought a few months back and was looking for some pointers on a Herculiner roll on product. He is scuffing the bed with sandpaper and brass brush. I will double check his work once the sun is off the surface. I missed my opportunity to get this done when it was drier. It's going to be nearly impossible to avoid humidity. How will that affect the drying time and overall product longevity?
Also, there are some plastic plugs in cutouts in the bed. I had him remove these plugs but I got to thinking that a thick product may keep them from going back in. I could always roll the product on top of them or leave them out altogether. I don't plan on any heavy hauling in this thing since I have a 1500 as well. Thanks for any tips.
https://www.amazon.com/dp/B0002TDUW4
I did this to my 2012 Ram several years ago. I took the plastic liner out. I scuffed the bed slightly and have not had any issues. I have had pallets and a few other things loaded in the bed with no issues. This stuff is pretty durable. Obviously not as good as a Linex spray in liner, but it was well worth the money.
I removed the plugs and mine popped back in. I think you will be surprised that it is not as thick as you think...
Thanks for the reply. I will leave the plugs out for now. I hated the plastic liner in my Dakota but left it in due to all of the scratches it caused. The factory bedliner in my Ram is very nice but I don't want to spend that much on this beat up truck.
put a nice tape edge around by the tailgate and lights. That Herculiner is good stuff. Just scuff and the bed. I used a blue foamy roller.
It held up for years
Have done it. Glad I did. As @TnT_M said, it’s thinner than you’d think. I tried to go cheap and it was too thin … best to buy the real suggested quantity. Sharp corners dug in hard can tear it, but it’s easy to touch up if someone cares.
If it was me, wash the bed down with Dawn or Blue Coral/Black Magic car wash without wax. Go to your local auto body shop supply house and get a few red Scotch-Brites, prep paste(SEM Soap, Scotch-Brite scuffing paste or similar), wax and grease remover and maybe some 2K epoxy primer in a can for any bare metal you see. Take the plugs out. Wash the bed. Use the wax & grease remover to remove any oils/grease of silicone. Apply it via spraying it on or a rag but wipe it off in one direction only. Scuff it good - the reason why I say get the prep paste is that it has surfactants to degrade and fine abrasives that scuff the surface better than the scotch-brite on its own. You’re creating a 400-600 grit sand scratch. Rinse and make sure water sheets off and doesn’t bead up. If it does, you have silicone or wax contamination. Repair any sand-through to bare metal with the epoxy primer.
Keep in mind the DIY stuff is a 1K urethane with no isocyanate hardener. U-Pol makes a 2K DIY product I’ve seen at the parts store. Raptor is tintable(using solventborne basecoat tinters) towards your truck’s base color as well, IIRC.
You have to really skuff the paint until there is no gloss of shine for the roll on bed liner to stick and stick well. Get it right and 20 years later it is still working great get it wrong and you would think it was white wash on an old fence.
I did it 3 times the first time I had to redo it. The other two times it looked like it was factory and I even did the top of the bed sides. You have to really cut through the clear coat to get it to stick well.
I hate to be that guy, but for the few hundred bucks you save, it isn't worth it for a one-and-done job. Just pay for the entry-level spray on option from one of the many bedliner places.
The OP mentioned it was a work truck. Not someone's "baby".
I bought a used garden cart for lawn tractor where the sheet metal had surface rust. Prepped it with a metal rust treatment then a cheap can of bed liner paint from Home Depot (I assume). Many years later it had not peeled or flaked off. And I dumped stuff in it and shoveled stuff out of it.
I had my 2015:F250 done at a local shop with a product similar to Linex. And then put down a plastic/rubber mat to protect the bed liner.
