Just curious if using a thicker oil MT90 in a older transmission that calls for MTL (Civic 93' 5 speed). When I first got the car 126K, the gear would grind from 4th - 5th at rpms above 4K. I switched out the oil which looked like 10w30 to MT90 and after a couple hundred miles it went away, however I can feel a little bit of roughness from 4-5 at over 4K rpms.
Anyways, I wanted to go with MTL,but my friend suggested MT90 due to the age of the transmission and would provide better protection.
However during cold weather I notice its always harder to shift (notchy) into 1st/2nd, no grinds though.
I do let the car warm up before doing any crazy shifting. Is there any harm using thicker oils? Should I switch to MTL?
Thanks
Thanks
