Rivets on 3 piece metal head gasket? Should I remove these before installing?
British Columbia, Canada
Got an aftermarket Vertex gasket kit for the Honda XR650L; wondering if I somehow have the wrong gasket or if I'm misunderstanding how it works?
The 3 piece metal head gasket appears to be a bit different from the OEM Honda in that it has copper/brass rivets holding the 3 metal gasket sheets together. The rivets do line up with cavities in the cylinder side, but on the opposite cylinder head surface where those rivets would sit against is just flat/smooth so I'm confused with how it will seal??
Here is a pic of my cylinder and cylinder head with the Vertex gasket install on the cylinder:
You can see the brass rivet on the head gasket (red arrow). The cylinder does have a cavity behind where each of those 4 rivets sit. However, on the other mating surface (the cylinder head) the mating surface is flat (blue arrow) - how is that supposed to seal?
Can someone confirm if the Honda OEM head gasket is the same design with rivets? I don't recall seeing those when I took the old gasket off a few months ago. I tried to search for a pic of the OEM head gasket online and looks like no rivets:
Which of the 2 heads are you using? The one that gasket is sitting on looks like it'll be fine?
Also too, there is a rounded trapezoidal shaped hole on the cylinder head, between the round holes near the large rectangular opening. Why doesn't the head gasket have a cutout for this?
Scott
Scott
No idea, but looks like the OEM Honda gasket (last photo in my original post) ALSO doesn't have a cutout for this interestingly enough!
What do you mean? The photo shows the cylinder and cylinder head, so those would be the two parts of the engine that will be mating together using the gasket. One has cut outs which the rivets sit in, but the cylinder head has a flat surface as you can see, hence the question!
Post a picture of the barrel without the gasket.
Yeah don't mind me... Evidently I was being retarded 🤣
You should be fine - the rivets are above the holes for the cylinder base fasteners - that is enough relief and wont stop the head from sealing.
The rivets are nowhere near the sealing area. There is no issue with this.
Yeah so many vehicles have head gasket problems nowadays and they all use MLS. :ROFLMAO:
Perhaps that’s not due to the gasket. Personally I’ve never had one fail but maybe that’s just me.
Sometimes people’s perceptions of root cause aren’t actually where the problem lies.
