Anyone ever used Real Gaskets Tennessee brand silicone gaskets? I'm still in my 40+ -year ongoing battle to find valve cover gaskets that last more than a couple of years in a big-block Mopar with stock factory high-performance manifolds that sit about an eigth inch from the passenger's side valve cover, and cook the gasket to crispy critters. I've had decent luck since switching to cast aluminum valve covers and Moroso rubber-over-metal gaskets, but I did have one of them fail recently. I've also taken to sliding a strip of header wrap insulation between the manifold and the valve cover, so that helps too.
The Real gaskets are pure silicone rubber . The upside is that they're good to 400F and are reusable, soft enough to mold into the as-cast gasket surface that old cylinder heads always had. Downside is that they are pretty squishy and require very low torque (20 in-lb), and probably loctite on the bolts.
I'm going to experiment with them, but was just curious if anyone here had tried them before. Apparently they're a big supplier for general aviation, with lots of rocker box and valve cover gaskets for Lycomings, Continentals, Jacobs radials, all the way up to P&W and Wright radials.
For those who aren't familiar with the upswept BBM performance exhaust manifold and how close it is to the valve cover, pics with OEM and cast aluminum valve covers:
