Rislone Diesel DEF Treatment
If seems like additive companies will make a solution for every type of fluid out there. IMO nothing is needed for DEF if you keep it fresh. DEF has a shelf life and bad things can happen to an expensive system if you don’t keep it fresh. I don’t have a DEF diesel but if I did I’d keep the tank closer to empty than full to avoid issues.
Just my $0.02
Interesting. The only issue I’ve had on my truck in 60k miles is 3 ECLs that all came back to emission sensor. All 3 times the ECL went away after a couple of days
DEF crystalizes when it is exposed to oxygen. As long as your system is closed, you shouldn't be seeing crystallization.
