No I just mean it snapped while tightening it, it's just a regular bolt, although it's way below that plate, sorry picture doesn't show the angle.If you remove the other bolts it looks like that plate should come off. Then you might be able to flatten the broken bolt enough to drill it. Are you saying it has left hand threads? You can use this kind of extractor: https://www.summitracing.com/parts/...MIoKf50eiS_QIViBTUAR0FLwo0EAQYBSABEgKcq_D_BwE
Probably, but I don't like that.Aren't the 2 other bolts enough?
There won't be enough as this is way below the plate.As noted take the plate off. Then try and grab the reminder if the bolt with a Vise Grip.
Power steering pumpIs that a water pump? It might be easiest to just replace it, and let the rebuilder worry about extracting that broken piece from your core. Drilling out a jagged, broken, recessed bolt is near impossible in my experience.
My experience with those things is they break in the hole and now it's 10X as hard to get out.Remove plate, use the appropriate size EZ Out bolt extractor
This, I have seen it work with my own two eyes. My kid did it for me.Remove plate, mig weld nut to broken bolt.
Yes it is. But below the level of the pump housing?There won't be enough as this is way below the plate.
Exactly. Center punch as best as possible, then drill with a left-hand bit.If the head just snapped off when tightening, it might be loose enough to back out with a pick tool.
https://www.harborfreight.com/14-in-titanium-drill-bit-set-4-piece-64904.htmlI have an easy out set a friend lent me, but I don't have bits strong enough to drill a starting hole.
