Originally Posted By: Donald
Originally Posted By: Billbert
1 oldtimers trick is to hook up a good battery in parallel and then slow charge it overnight (7 to ten amps) Best chance of revival.
Won't there be a large flow of current from good to bad when first connected?
No, because lead-acid batteries don't accept much charging current until the applied voltage is ABOVE the open-circuit voltage. You can't really get much charge into a "dead" battery from a "good" one, although a little bit will transfer. I think the paralleling trick is more to 'fool' the charger into keeping on charging. Normally when you put a "dumb" charger on a badly sulphated battery, it'll just show full charge quickly then kick off (unless it has an 'equalize' mode you can choose, or similar). Modern multi-stage battery chargers will do a lot of this on their own without having to fool them.
That said, I think having been frozen pretty much guarantees this one is DOA. If it hadn't already been dead, it wouldn't have frozen in the first place. Double whammy... and freezing does actual physical damage.
