Review: Pull It Out Concrete Oil Stain Remover
CA
I spilled some oil onto my driveway and needed to remove it.
Product:
Prior to application I did scrub the area with ZEP Purple degreaser, but this resulted in a minimal improvement. This is a very thick product:
After 8 hours:
I’ll let it sit for a full 24 hr before removing and reporting back with final results.
Product:
After 8 hours:
Have you tried pour n restore? It really works. For many of the thicker concrete cleaners you're supposed to take a wide putty knife and spread it thin about an inch or two past the stain. This stuff usually shrinks as it dries.
I always used kitty litter and ground it in with my feet, left it there, and by the time the wind blew the kitty litter away, the stain was gone.
I think rain probably helped, too.
This product might be useful for a spill inside a garage or in a place where it rarely rains.
Followed a similar path with Zep purple, so watching with interest. $18 bucks doesn't seem like too much of a risk.
But with my six-month old stain, I wouldn't get my hopes up. Slab needs to be replace anyway.
Do you think this would make a good engine cleaner, instead of Archoil or HPL?
(jk)
Mike - does it say it will remove all types of oils?
I got a little nuts with TUNG OIL on my cedar over concrete gate/fence. It actually is getting better with age, but still.
That looks a lot like the Goof Off product. It worked well on a fresh oil spill about 8" in diameter, followed up by scrubbing some full strength Dawn dishwashing soap on the remaining stain and rinsing off. It was absolutely worthless on a old oil stain that was in the garage when I moved in. I'm convinced that nothing works on those. The trick is blotting as much oil up as possible and then using a product to get the rest before it has time to soak in and "take a set".
I sprinkle the clay stuff on the stain, grind it in with a piece of particle board until it's a fine powder and let it sit. I don't usually have to sweep it up as the wind blows it away.
It does leave a whiter than concrete spot that eventually washes out IF it rains hard enough.
