after you get the concrete clean put a concrete sealer on it. for $60 I did my new driveway (700 sqft) and oil does not penetrate it it just wipes off with no stain.
Nothing works as well or is easier to use than a product called "Pour-N-Restore". It is often available at your local ACE hardware stores for ~$13 a quart. It's also available at their website: http://www.pour-n-restore.com . I was skeptical until I tried it...it really works as advertised.
I’ll tell you about a wonder product that has worked amazingly well on my driveway. The product is Oil Gone Easy S-200 Home & Driveway. I poured it on the oil stain and the next day it had done its work. It works well on both cement and concrete surfaces. The best part is, it does not require any cleanup after use.You can learn more about the product at ....
Originally Posted By: Nukeman7
Nothing works as well or is easier to use than a product called "Pour-N-Restore". It is often available at your local ACE hardware stores for ~$13 a quart. It's also available at their website: www.pour-n-restore.com . I was skeptical until I tried it...it really works as advertised.
Ditto on this! I recently tried it for the first time. My local Ace didn't carry it, but ordered it for me - only took a day or two. I was stunned at how well it worked. I went back to Ace and told the owner how well it worked and dared him to come over and tell me where the stains were. I literally can see NO trace of where the oil was.
I will say that I rinsed the residue off after sweeping up the dried product.
Originally Posted By: david123456
I’ll tell you about a wonder product that has worked amazingly well on my driveway. The product is XXXXX. I poured it on the oil stain and the next day it had done its work. It works well on both cement and concrete surfaces. The best part is, it does not require any cleanup after use.You can learn more about the product at http://SPAMMER.com
Didn't this strike anyone else as odd? A first-time poster reviving a thread dead for over a year with a post that sounds like advertising copy, complete with a URL?
