Well.....things happen. Was getting my boat lake ready and installed the battery. The previous owner had some mickey mouse wiring he did to install the radio and depth finder. Thought I had it all figured out...NOT. Hooked the negative to the positive, this is my boat, but it's a 3.0 GM engine. I turned on the master switch and noticed the negative spark, then heard a faint sound, I immediately turned off the master switch. It was on for maybe 4 seconds. I then noticed and smelled smoke coming off the alternator. Kraph….after I regained my composure, I followed all the lines and got them connected the right way. Kept my fingers crossed and all gages worked, hydraulic pump worked, bumped the starter, it works. Hooked it up to the water muffs and engine cranked. No smoke or anything coming off the alternator. Noticed the volt meter was showing 13 volts. When I turn on the blower or some other aux unit, volt meter would dip down a little, as it normally does. When I rev the engine, volts go up. It's like nothing ever happened. I don't get it. I didn't have my volt meter with me to confirm the alternator output, but have no reason to believe that it's not off that much. This is a factory installed AC Delco marine alternator, 1996. Have never had problems before. Noticed the starter cable got hot, but nothing melted or fried. Can I trust it? Seems weird that something smoked and it works fine.
