My plan is to do a drain and fill every year. I drive around 12-15k a year. Jeep recommends a drain and fill every 30k after 100k IIRC so I'm assuming that is what the filter is rated for.
Should I just remove the fluid from the filler tube and change the filter every other year? It would of course save money on the filter ($10.. big whoop), but also save time on removing the pan and dealing with the mess. I would also assume as mileage increases on the filter, so does its efficiency so it would be pointless to remove early.
I had to do a drain and fill 6 months apart last spring because of a leaking pang gasket. I would loose around a half a quart of fluid per week.. it was bad. The filter looked new and the pan magnet had little to no sludge whatsoever. Fluid has been changed w/ filter at 100k, (pre BITOG exposure period
) 145k and 155k.
*Just realized my mileage and month math doesn't add up. It would have had to have been less than 10k between fills. Drained it Sept. 2013 and May 2014. I need to keep a log book!
