That’s all within spec and good. But I’m still used to seeing a pegged needle at cold start until the oil all truly heats up.No problem as long as the pressure gauge reads at least 1 bar at idle and is pegged before the engine reaches 1500 rpm. Do you notice a difference between different oils usually?
TBH my OCIs are seldom, and sometimes go long durations. I’m just used to seeing a cold start pegged, even when running 5w-40.
But the pressure in use is perfectly fine, and the engine runs smooth and well.
