I kind of like the Liqui Moly Mos2 engine oil additive, it stopped the VVT actuator rattle on my 2015 Honda CRV engine at cold start. That rattle started about 60,000 miles and the correct way to fix it would have been to replace the VVT actuator. I may use the stuff on my new car with the 0w-16, but I thought I would ask Liqui Moly their thoughts on using it on a vehicle under warranty. Yes, I realize you shouldn't use additives, should use 5w30 no matter what the owner's manual says and all that, and of course, whatever oil is cheapest at Walmart. But anyhow, I thought I would share what the response was back from Stefan at Liqui Moly:
Joel,
MoS2 cannot affect engines in any negative way, it will only reduce friction which will equal better protection. According to the Magnuson-Moss Act (federal legislation) it is illegal for a manufacturer to refuse warranty based on non OEM parts or lubricants used. If they would by chance refuse warranty, they will have to provide proof that whatever product (or part) that was used, caused the damage.
MoS2 Anti Friction will strengthen the protective lubricant layer when used with any engine oil including a modern 0W-16 viscosity oil.
We hope this information proves helpful. If you require any further clarification or have additional questions, please don't hesitate to reach out. Our team is readily available to assist you.
Regards,
Stefan Braun
Application Specialist
Joel,
Regards,
Stefan Braun
