nope. Most resistor plugs are of copper alloy electrode, and they (the copper alloy electrodes) erode away over time, causing difficulty to fire (which requires higher HT voltage in order to jump gap).
The resistor element inside is a form of fused carbon compound under high heat, so it will not electrically deteriorate over time. On the other hand: the carbon element on spark plug wires aren't the culprit when it comes to failures; instead: it's the breakdown in insulation properties of the sheath (skin/sleeve) of the silicone or rubber jacket that causes all kinds of trouble (mainly).
Remember: you are exerting over 6KV+ of high tension through these cables in order to spark a spark plug under all elements, and that's a serious punishment to all the possible insulation materials such as silicone, rubber, etc.
Q.
