JHZR2
Staff member
Quote:
I just got off the phone with an ISO 9000 lab regarding running a GC on a Mobil 1 sample. The PhD who I was referred to, who runs the GC analysis, indicated that he had been through this before, however, with a lubricant manufacturer's oil he was testing, *knowing* the oils makeup, yet got inconclusive GC results as a result of molecular weight overlap between the PAO component and the Group III component.. The company supplied several iterations of the engine oil and the GC still reported unreliable results regarding the PAO and Group III content.
Irrespective, I am going to submit some sample of Mobil 1 and see what we get.
This makes perfect sense. I am using an FID-equipped (Flame Ionization Detector = FID) gas chromatograph for analysis of fuels. In the end all, chromatography is merely a COMPARATIVE measure, so one has to have reasonable known standards to compare to or at least to make a good educated guess against. Someone who doesnt look at similar species in a consistent method may not be able to do direct eye comparissons, whereas someone who has done similar things for decades (like Tom) certainly may be able to.
I would gladly run samples in my GC, excxept that my understanding is that you need a column set up for at least 350C, where mine are rated only for 320. With heavy feeds, a few degrees can make a LOT of difference.
JMH
