I was watching this video of some youtuber who suggest that we should considered replacing the radiator cap, thermostat, and water pump at some interval. He was suggesting that may be every 60K the radiator cap and thermostat should be replaced. The radiator cap because the seal breaks down and it no longer holds the pressure it used to. The thermostat may eventually failed. The water pump should be replace when you change timing belt.
I do recall that in my first car, my thermostat seems to fail often resulting in overheat of the car and probably contributed to its demise. In the past, I always replace the water pump every timing belt change, but the Subaru dealer suggested that it wasn't really necessary since the water pump is quite robust. What do you think?
Paul
