I think it’s time for me to stop being lazy about it and replace the shocks in a 1999 Suburban 2500. The truck has about 170k miles on it, no idea if the shocks are original but I’d guess they are either original or otherwise pretty old. There’s evidence of leaking on one of the fronts, the rest look old but OK. The damping isn’t THAT bad but it could be better and I’m looking for a little better stability while towing.
So, just as a sanity check: the dampers and springs are separated both front and rear (leaf springs in back, torsion bars up front) so I won’t have to mess with the springs at all. Is there any reason I shouldn’t be able to just swap the dampers with the truck sitting on the ground, no jack involved? Ground clearance looks good enough for wrenching positions although I will need to double check. Seems like it should work out but I wanted to make sure there’s nothing stupid I’m missing.
