Replacing PCV valve
CA, USA
Just ordered PCV valves for the sienna & highlander in my sig. I'm having slight oil consumption (1 qt/5000 miles) and I doubt it has been done on either vehicle. I've never changed one before. At least the Sienna looks simple enough.
Do I need to apply anything to the threads when I put the new one on? Or just twist it on with the same wrench that I took the old one off?
Did you mean, "just so it doesn't BEND given its plastic?" Just trying to get your point here.
They usually end up with oil on the threads coming out, but if not put a little something on the threads - just so it doesn't bind given its plastic.
IIRC, it is metal thread and metal PCV.
It should come with some sort of sealant so you just take off the old one.
Clean the hole and reinstall the new one.
There may be some parts needs to be put aside to get to it.
I hear this all the time. But does changing the PCV valve really helps with the oil consumption?
I know a clogged valve will cause valve covers to leak though.
The PCV valves(OEM) come with a sealant.
In some cars like Volvo's a clogged PCV system w/ putout the seal do to an increase of crankcase pressure.
