I have it narrowed down to these two,
Driver side is crackling. And I'm looking to upgrade..What's wrong with the speakers you have now?
Well 5x7 and 6x8 is what will fit in there. Without going too much smaller.I'm a bit confused as to why the finalists are a 5x7" marine-rated speaker vs. a 6x8" which doesn't appear to be specifically marketed as marine-rated.
With either one, I do think you're on the right track with a fabric tweeter. Metal tweeters sound too sharp to me.
Is listening to them in person an option? At the risk of regurgitating something that is mentioned in nearly every speaker thread ever, sound is subjective. What sounds good to me with my preferred music may sound horrible to you with a different genre or EQ settings.
Ahhhh....the good ol days!I would just go to K-mart and get a set of Krako 6x9's
They're both great speakers. Flip a coin to decide.I have it narrowed down to these two,
Polk Audio DB 572 or Rockford Fosgate P1683
they will be going into my 13 Ford Edge, I will be running the stock head unit, with the 4.2 inch screen. I will be running a JL audio xd600 V2 6 channel amp. No subwoofer right now. Does anyone have any input on these speakers? And what would be best? Thank you..
ThisBe aware that the stock head units I’ve paired with aftermarket speakers has resulted in positives AND negatives. In a Focus, the aftermarket speakers were clearer, but all low frequency (bass) was gone. Even in past instances where I’ve used an aftermarket HU and amp, the speakers were not as powerful in the low-end. I mean, door speakers aren’t really the solution to adding more bass AND quality mids/highs, so this is more for information than anything.
The Rockford is a 3 way and the polk is a 2 way - i would typically go with the larger cone but the larger tweeter array may negate any advantage.
Sensitivity slightly better on polk.
Honestly, neither and give the
Infinity Reference REF-8632CFX
Serious consideration in that price class.
Did you pair it, with a subwoofer and amp to improve the sound of the factory radio?They're both great speakers. Flip a coin to decide.
I'm not trying to deter your choice, but these are what I have in my F150 (all 4 doors). And they ROCK!
I used to have an Alpine CDE-170 head unit in it. All I have ever used since I was 15 years old is Alpine. My son gave me a BOSS 7" screen head unit for Christmas. It has 20 watts RMS, 85 watts peak. I have a TC-10 Kicker 10" subwoofer behind the seat with an Alpine mono amp (150 watts RMS, 300 max) pushing the subwoofer. Believe me, it can be heard very clear outside at great distances.Did you pair it, with a subwoofer and amp to improve the sound of the factory radio?
I seen them Sonic electronics even less than that, Amazon has them all four for $99The Rockford is a 3 way and the polk is a 2 way - i would typically go with the larger cone but the larger tweeter array may negate any advantage.
