I finally got an opportunity to do some work on my daughters 2021 Mazda CX-30 as she's away on vacation (she lives an hour away from us and works a lot). The car has almost 88K miles so I changed the AT fluid for the 2nd time (D&R), oil& filter, air filter, cabin filter etc...I noticed her brake pads were nearly shot so I did a pad slap (I had the pads and the rotors looked good). I then noticed the rear brake pads were almost shot so I ordered pads from RA which surprisingly came the next day.
Yesterday I went out when the engine was cold and replaced the OE spark plugs with new NGK Rutheniums and then proceeded to replace the rear brake pads after putting the e-brake in 'maintenance mode'. When I went to start the car after finishing the brakes it stumbled and stuttered and sounded terrible. I assumed it had to be the new plugs as it ran fine after the 1st day's maintenance so I put the old plugs (which looked pretty good for the miles on them) back in but no change. I checked the wiring to the coil packs and all looks good. I disconnected the battery overnight and even touched the positive battery terminal to the negative for an hour to reset the ECM to no avail. I'm wondering if the 'ebrake maintenance mode' procedure caused the computer to get flaky? Any ideas from those more knowledgeable than I....I'd hate to have to flatbed it to the dealer?
PS: At first after changing the plugs I was able to drive it around the block with low power and stumbling etc...but now I can't even get it to run.
