2004 Mercury Marauder
My accumulator rotted out, and lost all refrigerant overnight. I ordered a new one and replaced the orifice tube, and all o rings on the lines I pulled apart.
I’ll use the ac machine at work to vacuum and charge it, but how much oil should I add to the system? The machine I’ll be using gives the option to add oil before charging.
I’ve read 3oz is common to add for accumulator replacement, but I’m not sure and would like other opinions.
thanks!
thanks!
