Originally Posted By: mehullica
Whatever you decide to use as a fluid in the trans, make sure you "reset" the learned memory in the ecu. It learns shift speed & rpm, once the fluid gets changed it will apply the clutch packs in the same learned pattern. New fluid will cause the clutch packs to slip & it will cause friction plate wear. Once the memory is reset, it will learn to shift quicker & reduce the wear that without a memory reset can take over 1000 miles
and how s this done
and how s this done
