Replace Honda MTF - Can't Find Synchromesh
Originally Posted By: MolaKule
Originally Posted By: mauric3
So would having amsoil mtf mixed with honda oem mtf be a good combo or pure amsoil mtf is better or just stick with oem mtf? Apparently the oem honda mtf right now is supposed to be better especially in cold start? does the oem honda mtf have synchromesh in it?
As I stated in the above post #4150957, the Honda OEM MTL IS a synchromesh fluid.
A synchromesh fluid is a dedicated MTF that has a specific additive package for the synchronized MT's.
I would not mix the fluids for various reasons. Use the Amsoil product.
Thanks for the reply.. i actually asked amsoil about mixing and the tech said its alright to mix but still recommends using pure amsoil mtf..
Originally Posted By: Hounds
Highlander, Reader's Digest version: If you can't find a source for Amsoil, I recommend mixing "Genuine Honda" MTF with Mobil 1 5w30 in a 50/50 ratio. You won't believe how well it works.
Or some ATF . Check the lube level. It may be low.
