Repairing Rear Defogger/Defrosters
Only to read the directions, and don't skimp on cleaning.
And give it the proper cure time.
Those repair kits work well for opens in the circuit.
I never replaced a tab with one.
I have actually soldered some on and they worked well! This is not recommended. Other stuff can break or be made worse.
When the tab fell off, I tried the glue on kit from Permatex. It worked for about 2 yrs. Then I made a pig tail with a large ring terminal on it. I pushed the ring under the window gasket with the tail against the contact patch. It was still working when I retired the car 5 yrs later.
Well I tried the Permatex repair kit and it does not work. Stuck well but not conductive enough to make defroster work.
I have ordered the Frost Fighter repair kit.
