Repair or replace this tire
The plug / patch is in same location as the picture at start of thread . It was a screw . Will get pictures of the patch / plug when I have the chance .
The tires are 7/32 rear 9/32 front.
The picture does look more worn that it really is though. Maybe it's the angle I took the picture. But the tread is in pretty good shape.
Doesn’t matter. Where it’s at: unsafe, so replace the tire. If I plugged that tire I’d be unemployed
This is same tire with the patch ( above ) . Looks like it may have caused uneven outer wear on both edges . Had to take it back to get no vibration . It has about 8/32s' left . Took pictures today .
Not all places will patch it since it is in the outer treadblocks. I had one like that and didn't want to get new tires yet so I plugged it. I ran it for months before I got around to pulling the nail out and plugging it actually. The tires lasted until they were worn out. Mine were older than yours however so I only needed it to last another season. Now if it was my Suburban that hauls my camper and takes long road trips over many states during the summer, I'd get a good patch if someone would do it or I would replace it.
Those arrows are pointing at missing sipes - and the sipes are missing because they are at a mold split. Notice the flash line in the groove. That was done intentionally by the tire manufacturer.
You do NOT have wear issues!
Ditch and replace. Any tire shop with a conscience will *not* plug/or mushroom patch a leak that close to the sidewall. Generally if a puncture is in the groove or closer to the sidewall on any outside tread block; it's irreparable.
Can you do it in the driveway with a gluey-rope plug? Sure. Be it on your head.
Yes, the TIA is very good at protecting the liability insurance of tire shops by providing simple, one-size-fits-all advice.
It’s a universal standard. And not a bad one. You can do what you want with your own vehicles.
