Repair and check the pressure more often.The hole is right at 1/2 inch from the edge of the tread. I did go ahead and plug it. Would you run it or get a new tire?
Doesn’t matter. Where it’s at: unsafe, so replace the tire. If I plugged that tire I’d be unemployedThe tires are 7/32 rear 9/32 front.
The picture does look more worn that it really is though. Maybe it's the angle I took the picture. But the tread is in pretty good shape.
This is same tire with the patch ( above ) . Looks like it may have caused uneven outer wear on both edges . Had to take it back to get no vibration . It has about 8/32s' left . Took pictures today .
View attachment 95976View attachment 95977
Those arrows are pointing at missing sipes - and the sipes are missing because they are at a mold split. Notice the flash line in the groove. That was done intentionally by the tire manufacturer.
You do NOT have wear issues!
Yes, the TIA is very good at protecting the liability insurance of tire shops by providing simple, one-size-fits-all advice.TIA says replace any tire with a puncture outside each outer most tread groove.
