Repacking trailer wheel bearings
After a trip i noticed one of my hubs felt cold
I took it out for a drive and used the brakes a good bit. The right rear is the only one cold.
I found the problem.
Ive had great service from ez-lube axles on my previous travel trailer , and this one until now.
The axle seal leaked, and grease contaminated the shoes.
I ordered a brake set. I will degrease the drum and repack the bearings.
I think I will forgo the ez-lube method now. And just do 10k repack/ inspections from here out.
EDIT:
I used Mobil 1 grease previously and it always leaked red out of my grease gun. I know other members here have had M1 grease leak and bleed out of grease guns.
No other grease has done that. I think the M1 grease leaked oil past the seals.
If you look at my pic. The grease on the shoes is all red.
The newer blue grease is Valvoline Cobalt. They are compatible btw.
https://rvthe.us/community/threads/cold-drum.1134/
  • Love
Reactions: D60
I'm still using Mystik JT-6 Grease that I found on the side of the road.
I've found seals last around 6 years max. I found some trailers a work made in 2019, some one went to minimum effort lengths to make it look like they did the wheel bearings. The OEM paint on the outside of the seals confirmed my suspensions.
EDIT:
Yeah they use a Mobil 1 grease where I work. The Mobil 1 leaks far more than everything else.
I've never had old hardened dry grease come out. I have several of these axles. I will admit it might take 20 or 30 pumps to get the grease to come out. Are you sure you're just not pumping it enough?
