So I can't put it off any longer. In the fall I took the cylinder head off the briggs to clean it out. Put it back on. Well, one of the small bolts holding the front of the shroud on... Well, when I tightened it down (not even that tight) the bolt head sheared off the rest of the bolt. Uh oh. I decided since I was putting it away I'd worry about it in the spring. Well it's almost spring. Anyone have any ideas how to get this thing out? Looking at this picture, it is one of the small bolts holding the shroud to the cylinder head, above the row of 3.
