How many of you have actually pumped ATF out of your transmission on a 01 F150 4R70W transmission? How much did you get out of it? Did it work OK? What type of pump did you use.
Thinking about doing that as I just don't have the time to get underneath it do the pan drop. Trans has about 31K on it, so I'm going to assume that the filter should still be fairly clean. The reason I want to do this is that I've read on other forums that the 4R70W is a beast that likes new fluid, a lot.
