Originally Posted By: daves66nova
why and when do you actually require a bypass on a filter?
Ah ..I detect a Chevy man who plugged his bypass
Aside from loading ..the bypass protect the engine from starvation of oil. It's needed because you have to have a pressure relief on your oil pump.
Long story short, the bypass valve prevents oil starvation when your pump is in relief. The bypass setting protects the media.
If you're not in pump relief (which is when it's cold or when you're flat shifting at upper rpms) then you probably don't need one except (maybe) for the brief time that it takes to envelope the internals of the engine and produce "back pressure".
With the in block bypass defeated you could be driving around with breached media and be totally ignorant of it. In a worst case scenario you grab an Ecore with a plastic cage and have the media turn into a sail crushing it and clogging your oil outlet.
There is no upside to this practice that doesn't get trumped by potential liabilities. No one has yet to defend this practice nor a clue of who came up with it and why.
As I offered, it's not like Ford and Mopar are grenading due to not being able to do this.
