Little background: I have a 1991 Ford Explorer with the automatic A4LD transmission with factory auxiliary cooler. I recently replaced the rubber hoses on the aux cooler and noticed the ATF that drained out was darker than I had expected. It was closer to black/brown than it was to fresh, clear ATF. I will be dropping the pan in a few months to replace some seals and the internal filter (which I hear is just a screen?) and will put in fresh fluid after that.
In the mean time, I've been reading about remote filters like this:
http://www.napaonline.com/Catalog/Catalo...8429_0101899816
I've seen all kinds of praise and smoother shifting claims after 100-200 miles and I'm tempted to get one installed because... what could it hurt?
My main question is; what about the bypass? The transmission fluid will be at a pretty good pressure and even though it's thinner than a motor oil, would it even pass through the filter element or would it all end up being bypassed through the filter's valve? I see specs on filters saying they should withstand the potential PSI of the fluid (burst pressure?) but they all seem to have a low bypass pressure rating.
I currently use the Motorcraft FL-1A for oil and it would be a treat to use the same for the transmission fluid. Would this even work or would it be best to get a hydraulic-rated filter?
