Refrigerant leak through sensor wiring harness?
JHZR2
Staff member
New Jersey
Have a look…
In that wiring connector is dye and oil. Note, the spot where the wire connects to the red high pressure sensor body is sealed with a green epoxy.
But in the wiring connector is oil and green dye. It wasn’t there last week that I recall. The harness isn’t wet, it’s coming from the wire itself.
Has anyone seen this before? Refrigerant leak via a wiring harness?
It’s not enough to register a pressure change in the week since I filled it.
If this is the case, Ill probably have the system recovered, flushed, and filled with mineral oil to prep for r-12.
Staten Island, NY
Stranger things have happened
I know VWs like to have oil and or coolant forced down through the harness when a respective sensor/switch fails or leaks internally
Does the switch have a Schrader behind it, allowing a swap without a charge R&R?
dishdude
$100 Site Donor 2023
Phoenix
Not uncommon for sensors to have a seal fail and wick oil up through the wiring. Seen it with transmission sensors, engine oil pressure sensors.
JHZR2
Staff member
New Jersey
Btw. That receiver drier looks like it needs to be replaced.
Why? Just because of the surface rust?
The hoses definitely have some light surface corrosion, looks worse in photos with artificial light than in real life.
If/when I open the system to replace the sensor leaking out, it will definitely get a replacement r/d.
  • Like
Reactions: hrv
ah yes the old coolant level sensor
pressurized expansion bottle would force coolant through sensor wires to the fuse box, and a few people had coolant literally everywhere after the coolant made it through the whole harness.
Staten Island, NY
Only VW would have people confused
"I went to change my tail light bulb, but there's purple goo leaking from the wiring"
G12 coolant 😲
