JHZR2
Staff member
One of the garage buildings I own, which is probably 100 years old, has two tall garage doors. I don’t think they’re absolutely original, I think there was some sort of sliding doors there.
So figure they’re from likely sometime between 1926-1959 - the 40s or 50s, I’d guess.
Well the paint was long peeling, and at some point the prior owner slapped some paint on them and covered them with siding. They didn’t look bad like that, but I’d like to preserve them properly.
Some of the panels are failed.
The paint is either strongly adhered or flaking off.
I did replace the entire bottom row on the one door with a custom built panel set. The other door is better, minus the squares, but does have this:
I’m not really interested in replacing. The metal doors, while light, are all junk or industrial/ugly. Fiberglass is too fake, and another wood door will be lower quality. And everything is expensive for what it is.
I’d like to stabilize and get proper paint adhesion. And somehow fill in that corner. But more important is the paint.
I got out my festool stuff, wore a mask, and sanded everything with 60. The rest of the paint I’d say is pretty well stuck on.
I need to do something pretty water tight. The bottom level I made in the one door is already showing plywood panel failure.
So I need to seal, stabilize, replace some panels, form up things like this, with T88 and whatever else:
But to start, any recommendations on prepping the old wood to accept primer and paint?
